15 years agopush_button irq handler question
Hi, I use NEEK CycloneIII (CP3C25). App is quite simple it turns on the led corresponding the push button pressed (see code below). I copied irq handler procedure from standard binary_counter.c ...
15 years agoTried to display increment. That's what i got.
1. If I put usleep before IOWR_ALTERA_AVALON_PIO_EDGE_CAP(BUTTON_PIO_BASE, 0); it is incremented twice per button push. 2. If I put usleep after clearing function it is incremented once per button push. So i conclude the delay after clearing edge_capture reg is necessary.
