15 years agopush_button irq handler question
Hi, I use NEEK CycloneIII (CP3C25). App is quite simple it turns on the led corresponding the push button pressed (see code below). I copied irq handler procedure from standard binary_counter.c ...
15 years agoI haven't looked at your code closely but this sounds an awful lot like a simple button bounce issue. A common way to account for button bounce is to simply add a delay after first detecting the button press.
