15 years agopush_button irq handler question
Hi, I use NEEK CycloneIII (CP3C25). App is quite simple it turns on the led corresponding the push button pressed (see code below). I copied irq handler procedure from standard binary_counter.c ...
15 years agoHi,
Just a question, why do you not call the function init_button_pio in your main ? Because, like this, I would say it should do nothing since you do not initialize the interrupt. Jérôme
