15 years agoPthread_create hangs program
Hi, I'm trying to compile some C++ code that uses pthread on uClinux. I'm using this toolchain: http://www.nioswiki.com/index.php?title=OperatingSystems/UClinux/BinaryToolchain I ca...
15 years agoHey Kag,
I'm experiencing the same problem. Have you found a way to fix it? There seems to be with the linking process, I removed the -lpthread from the linker arguments and it doesn't complain about it. Is there a way to check this? Why does the GPP automatically links the phtread lib? And why does the GCC not. Would be great if you or someone else could help me. Thanks
