12 years agoProgramming NIOSII interfaced with custom component, using Avalon MM Interface
Hello Everyone, I am trying to interface NIOS II with a custom component using Avalon MM Inferface where NIOS acts as Master. During the C coding, how do i get access to the function to send/...
12 years ago --- Quote Start --- Hi, the code look like: always @(posedge csi_clk or posedge rsi_reset_n) begin // To read if (rsi_reset_n) begin end else if (avs_s0_read) begin avs_s0_readdata = START; end else begin avs_s0_readdata = 0; end end --- Quote End --- Its look like your code is correct. Still you can replace above code with this one always @(posedge csi_clk or posedge rsi_reset_n) begin // To read if (rsi_reset_n) begin avs_s0_readdata <= 0; end else begin case(avs_s0_address) 2'b00 : avs_s0_readdata <= START; default : avs_s0_readdata <= 0; endcase end end Apart from this what is the read and write latency of your Avalon interface.You can find it in your .tcl file.If write latency is zero then your write logic is correct and if your read latency is 1 then your read logic is correct. I have one doubt regarding reset.Is it active high or low? From the name of reset it looks like it is active low and you have used it as a active high. You can also find this from your .tcl file. Also make practice to use non blocking statement for sequential logic. Regards, Krupesh
