15 years agoProgram storage
I am designing a system that will have time-critical and non-time-critical instruction. I want to store all the time-critical instruction and data in on-chip RAM and the other in external SDRAM. How ...
15 years agook, well you will definetly need to figure out how to move some functions to on board ram and some to off chip.
I am going to be in the same boat shortly. I am starting to run out of on chip ram. I did a board spin because of this and put a ram on it just for this purpose. I will be trying to figure it out too. Have you done an OBJ dump yet? that will give you your memory map. I still don't know how to modify it though. I used to work for a company that was using TI DSP C55X and there we had several different levels of memory with different latencies. We were able to modify a linkmap command file and use pragmas in the C code to tell the linker which section to put each function in. There must be a way to modify some linker script in the Nios IDE. Problem is I am the only engineer doing board design, VHDL design and writing all the SW. I'm drowning! hopefully someone can help us with this cause I don't have time to blow trying to figure out something that should be in the Altera documentation. :(
