21 years agoProblems with program_flash utility, or is it?
Greetings, I downloaded ecos just recently. I have gone through the "getting started" documentation and I have run into problems. Here's my situation (note that I have used the standard example ...
21 years agoI restarted "from scratch" using the Verilog reference design. It works fine.
There's a chance I modified the VHDL design quite some time ago. The VHDL design had "unspecified board" selected, and therefore U5 was not a proper reference. I imagine the whole ecos build tripped on this. I went back to SOPC builder, changed it to Nios-Devkit-1S10ES and re-generated. I opened my library (first.ecc) and had the same problems. Actually, that's where I cut-and-pasted the above messages from. Nevertheless, my problem is fixed. Thanks for sanity checking this for me. -Terry
