15 years agoProblems with 16-bit DDR2-SDRAM connected to Nios
Hi, I am trying to implement a nios system(cyclone III) with 16-bit DDR2 SDRAM and 16-bit Flash device. While try to erase the flash device using the routine listed below unsigned in...
15 years agoThe actual problem is that, when i dont declare a 32 bit int variable to store the result of noofblockstoeras e*erasesize and use it as
flashutils_eraseflash(flashoffset,noofblockstoeras e*erasesize); the flash erase is executed only till 2^16 locations, even when i try erasing a larger block, but this works when i explicitly declare a 32 bit int variable to store the multiplied value. This may cause problems in my software application where i havent declared variables explicitly.
