15 years agoProblems in going through Altera Monitor Program Tutorial
My problem is in section 3.2 of the tutorial, "Compiling and loading the program." When I try to compile, I see the following in the info window:
Compiling source files... nios2-elf-as --gstabs -I C:/altera/91sp2/nios2eds/components/altera_nios2/sdk/inc -I H:/private/FPGA/monitor_tutorial H:/private/FPGA/monitor_tutorial/getting_started.s -o H:/private/FPGA/monitor_tutorial/getting_started.s.o Linking... nios2-elf-ld --defsym nasys_program_mem=0x0 --defsym nasys_data_mem=0x0 --section-start .exceptions=0x20 --section-start .reset=0x0 -e _start -u _start --script c:/altera/91sp2/quartus/../University_Program/Monitor_Program/build/nios_as_build.ld -g -o H:/private/FPGA/monitor_tutorial/getting_started.elf H:/private/FPGA/monitor_tutorial/getting_started.s.o nios2-elf-ld: H:/private/FPGA/monitor_tutorial/getting_started.s.o: No such file: No such file or directory Compilation stopped. It appears that the nios2-elf-as command, which I assume starts the assembler, does not generate the .s.o file. I've searched throughout the hard drive and cannot find it anywhere else, either. Any ideas what is going on?No RepliesBe the first to reply
