9 years agoProblems enabling hps2fpga & lwhps2fpga bridges
the problem:When trying to enable either the hps2fpga or the lwhps2fpga bridge in Linux, the Linux system locks up. From the rocketboards example: Command used: "echo 1 > /sys/class/fpga-brid...
9 years agoHi there, I will ask you a couple of questions just to double check and clarify my understanding of your problem:
Your post lets me to think you are using an example/reference design. If you are, can you specify which example are you using? Where you trying this by using a modified FPGA system? eg: where you using a compiled rbf of your own with modifications with respect to the GHRD? After you re-generated your dtb, did you have to re-compile any parts of your software? FSBL, kernel? Many thanks in advance!
