9 years agoProblems enabling hps2fpga & lwhps2fpga bridges
the problem:When trying to enable either the hps2fpga or the lwhps2fpga bridge in Linux, the Linux system locks up.
From the rocketboards example: Command used: "echo 1 > /sys/class/fpga-bridge/hps2fpga/enable" *or* Command used: "echo 1 > /sys/class/fpga-bridge/lwhps2fpga/enable" other useful information: -The FPGA is configured with a validated .rbf (and indicates in "user mode" per /sys/class/fpga/fpga0/status) -The fpga2hps bridge can be enabled/disabled normally. -The issue has appeared after we switched Linux versions and the configurator from Yocto to Buildroot -If the FPGA is configured with the .rbf and a reboot command issued, the bridges are up once Linux boots and our system functions normally. *unless we try to bring down the hps2fpga/lwhps2fpga bridges The issue in question has appeared since we switched our Linux environment. There is a high probability that we have missed a configuration setting that would be needed to properly perform this action - any suggestions on this front would be highly welcome. Not sure if it is helpful or not, the version from /etc/os-release indicates 2015.08-git. Thank you in advance for any assistance.3 Replies
Another day of troubleshooting and the problem has been fixed.
Once we re-generated the .dtb for the core system, everything started working normally again. I can't say specifically what was wrong with the previous one, but the guess is that our implementer utilized a .dtb packaged with a GHRD and did not generate it from our actual system. I hope this helps anyone with a similar problem. -Kosh271 - Altera_Forum
Hi there, I will ask you a couple of questions just to double check and clarify my understanding of your problem:
Your post lets me to think you are using an example/reference design. If you are, can you specify which example are you using? Where you trying this by using a modified FPGA system? eg: where you using a compiled rbf of your own with modifications with respect to the GHRD? After you re-generated your dtb, did you have to re-compile any parts of your software? FSBL, kernel? Many thanks in advance! - Altera_Forum
Hi! have you got a solution? Thanks.
--- Quote Start --- Another day of troubleshooting and the problem has been fixed. Once we re-generated the .dtb for the core system, everything started working normally again. I can't say specifically what was wrong with the previous one, but the guess is that our implementer utilized a .dtb packaged with a GHRD and did not generate it from our actual system. I hope this helps anyone with a similar problem. -Kosh271 --- Quote End ---
