15 years ago
Problems debugging simple program in NIOS II IDE
Hardware and software tools:
NIOS II IDE 10.1 ("Legacy")
Quartus II 10.1
Device:Arria II GX - EP2AGX260FF35I5N
I am using software tools and hardware as described and a custom board.When i am trying to debug through NIOS II 10.1 IDE ("Legacy") ,the simplest debug there is -Hello World ("Hello from NIOS II),i get connection message in the console and i see that USB Blaster is connected (Blue LED is on)- (i am using jtag uart),but i never get the message "Hello from NIOS II" in the console.If i try to program another simple program such as blinking LEDs it doesn't run/debug either.The problem is probably not in the board ,because at my work colleague's computer he is able to run/debug this simple programs without any problems.
    Dear cris72
    My fpga is EP3C120f484 and EPCS64.using the nios 9.0 and quartus 9.0
    Now I am meeting some problems with nios debug.
    the problem is in the nios debug window,the console print,here is my information:
    Nios ii download output: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
    Processor is already paused
    Reading System ID at address 0x00002C28: verified
    Initializing CPU cache (if present)
    OK
    Downloading 00040120 ( 0%)
    Downloading 00050000 (59%)
    Downloaded 108KB in 1.8s (60.0KB/s)
    Verifying 00040120 ( 0%)
    Verifying 00050000 (59%)
    Verified OK
    Leaving target processor paused
    nios ii terminal window:
    nios2-terminal: connected to hardware target using JTAG UART on cable
    nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 0
    nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
    Running...
    INFO : TSE MAC 0 found at address 0x00002800
    INFO : PHY National DP83640 found at PHY address 0x01 of MAC Group[0]
    INFO : PHY[0.0] - Automatically mapped to tse_mac_device[0]
    INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link...
    INFO : PHY[0.0] - Auto-Negotiation PASSED
    INFO : PHY[0.0] - Checking link...
    INFO : PHY[0.0] - Link established
    INFO : PHY[0.0] - Speed = 100, Duplex = Full
    Waiting for link...OK
    IP address: 219.245.66.185
    IP netmask: 255.255.255.0
    IP gateway: 219.245.66.254
    begin to send...
    nios2-gdb-server output
    Listening on port 1787 for connection from GDB: 59s58saccepted
    Exiting due to 'k' command from GDB
    nios2-elf-gdb
    mi_cmd_stack_list_frames: No stack.
    No symbol "new" in current context.
    Current language: auto; currently asm
    Current language: auto; currently c
    kill
    how is the problem solved,as I follow the ways with the website,it doesnot work!
    here is the website:http://www.alteraforum.com/forum/showthread.php?t=28506
    By the way,are you chinese?
    waiting for your reply ,thank you!
