Dear cris72
My fpga is EP3C120f484 and EPCS64.using the nios 9.0 and quartus 9.0
Now I am meeting some problems with nios debug.
the problem is in the nios debug window,the console print,here is my information:
Nios ii download output: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Processor is already paused
Reading System ID at address 0x00002C28: verified
Initializing CPU cache (if present)
OK
Downloading 00040120 ( 0%)
Downloading 00050000 (59%)
Downloaded 108KB in 1.8s (60.0KB/s)
Verifying 00040120 ( 0%)
Verifying 00050000 (59%)
Verified OK
Leaving target processor paused
nios ii terminal window:
nios2-terminal: connected to hardware target using JTAG UART on cable
nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 0
nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
Running...
INFO : TSE MAC 0 found at address 0x00002800
INFO : PHY National DP83640 found at PHY address 0x01 of MAC Group[0]
INFO : PHY[0.0] - Automatically mapped to tse_mac_device[0]
INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link...
INFO : PHY[0.0] - Auto-Negotiation PASSED
INFO : PHY[0.0] - Checking link...
INFO : PHY[0.0] - Link established
INFO : PHY[0.0] - Speed = 100, Duplex = Full
Waiting for link...OK
IP address: 219.245.66.185
IP netmask: 255.255.255.0
IP gateway: 219.245.66.254
begin to send...
nios2-gdb-server output
Listening on port 1787 for connection from GDB: 59s58saccepted
Exiting due to 'k' command from GDB
nios2-elf-gdb
mi_cmd_stack_list_frames: No stack.
No symbol "new" in current context.
Current language: auto; currently asm
Current language: auto; currently c
kill
how is the problem solved,as I follow the ways with the website,it doesnot work!
here is the website:
http://www.alteraforum.com/forum/showthread.php?t=28506 By the way,are you chinese?
waiting for your reply ,thank you!
