15 years agoProblems debugging simple program in NIOS II IDE
Hardware and software tools:
NIOS II IDE 10.1 ("Legacy") Quartus II 10.1 Device:Arria II GX - EP2AGX260FF35I5N I am using software tools and hardware as described and a custom board.When i am trying to debug through NIOS II 10.1 IDE ("Legacy") ,the simplest debug there is -Hello World ("Hello from NIOS II),i get connection message in the console and i see that USB Blaster is connected (Blue LED is on)- (i am using jtag uart),but i never get the message "Hello from NIOS II" in the console.If i try to program another simple program such as blinking LEDs it doesn't run/debug either.The problem is probably not in the board ,because at my work colleague's computer he is able to run/debug this simple programs without any problems.11 Replies
Dear cris72
My fpga is EP3C120f484 and EPCS64.using the nios 9.0 and quartus 9.0 Now I am meeting some problems with nios debug. the problem is in the nios debug window,the console print,here is my information: Nios ii download output: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Processor is already paused Reading System ID at address 0x00002C28: verified Initializing CPU cache (if present) OK Downloading 00040120 ( 0%) Downloading 00050000 (59%) Downloaded 108KB in 1.8s (60.0KB/s) Verifying 00040120 ( 0%) Verifying 00050000 (59%) Verified OK Leaving target processor paused nios ii terminal window: nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 0 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate) Running... INFO : TSE MAC 0 found at address 0x00002800 INFO : PHY National DP83640 found at PHY address 0x01 of MAC Group[0] INFO : PHY[0.0] - Automatically mapped to tse_mac_device[0] INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link... INFO : PHY[0.0] - Auto-Negotiation PASSED INFO : PHY[0.0] - Checking link... INFO : PHY[0.0] - Link established INFO : PHY[0.0] - Speed = 100, Duplex = Full Waiting for link...OK IP address: 219.245.66.185 IP netmask: 255.255.255.0 IP gateway: 219.245.66.254 begin to send... nios2-gdb-server output Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Processor is already paused Reading System ID at address 0x00002C28: verified Listening on port 1787 for connection from GDB: 59s58saccepted Exiting due to 'k' command from GDB Leaving target processor paused nios2-elf-gdb mi_cmd_stack_list_frames: No stack. No symbol "new" in current context. Current language: auto; currently asm Current language: auto; currently c kill how is the problem solved,as I follow the ways with the website,it doesnot work! here is the website:http://www.alteraforum.com/forum/showthread.php?t=28506 By the way,are you chinese? waiting for your reply ,thank you!
