20 years agoProblems compiling VHDL
Hello, I'm using the NIOS II Development Kit on a Stratix II board equipped with an EP2S60 FPGA. I need to implement VHDL blocks for image processing. My block needs to read pixels wri...
20 years ago --- Quote Start --- originally posted by lord_redbeard@Apr 14 2006, 09:49 AM hello,
i'm using the nios ii development kit on a stratix ii board equipped with an ep2s60 fpga.
i need to implement vhdl blocks for image processing. my block needs to read pixels written in memory (about max. 512*512 pixels). i wrote a for-loop in quartus ii 5.0, in a vhdl file, but it doesn't compile. one error occured which is :
"loop must terminate before or at 10 000 iterations".
but 512*512 pixels = 262 144 iterations !
i also tried to create a for-loop from 0 to 9999 and it works. so i thought i could duplicate this for-loop, but it doesn't compile too.
has anyone had the same problem, or does anyone know how to make a 262144 iterations for-loop ?
for the moment, the only solution i got is to make a 128 pixels memory acces in one iteration, but i want to know if a vhdl for-loop is limited to 10 000 iterations.
finally, i also tried to work with while-loops or illimited-loops (with an exit condition), but the problem still remains : 10 000 iterations maximum.
if you know what to do, feel free to answer. if my problem is not clear exposed, feel free to ask questions.
thanks for your reading,
lord_readbeard
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14377)
--- quote end ---
--- Quote End --- The design is rather interesting for me. Obviously it's a large design for single HDL hardware, whether or not VHDL either Verilog will support this logic level compilation is a question you might get answer for this by referring HDL library. But I have a feeling Quartus II might not to be able to build such a big logic as well as this amount of registers (I think you don't have access to on chip memory from HDL) in one design. For design goal's sake, I will suggest to use DSP builder or system level design methodology. Buffering data will help. Good luck, or if you have any update please post. For your reference: Stratix II EP2s60 has total registers : 52,506
