--- Quote Start ---
originally posted by nacide@Jun 13 2006, 04:05 AM
zhengkaike,
you need to have the commands that are called like mount, umount, grep, test, echo and sleep in your rootfs.
maybe it will also work with the busybox versions but i did not test this.
i call the shellscript from the rc script in /etc
for example
automount.sh &
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16150)
--- quote end ---
--- Quote End ---
Hi,nacide,
Thank you!
May be my busybox has some bugs,there are many errors when compiled.
I have resolved the problem by using mount() and umount(), it can work successful although it's not a best method. The code:
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
char spe_file[20]="/dev/sda1";
char cur_dir[]="/mnt/usb";
char um_dir[]="/mnt";
char subum_dir[]="usb/";
int main(void)
if(mkdir(cur_dir,O_RDWR)==-1)
//"/mnt/usb"exsit
if(umount(cur_dir)==-1)
printf("erro : umount usb!\n");
exit(1);
chdir(um_dir);
if(rmdir(subum_dir)==-1)
printf("error rmdir %s \n",subum_dir);
exit(1);
printf("umount usb ok!\n");
return 0;
if(mount(spe_file,cur_dir,"vfat",2,(char *)NULL)==-1)
printf("error :mount");
exit(1);
printf("mount usb ok!\n");
return 0;
}[/b]
--- Quote End ---
Thank you for your reply again.
