19 years ago
problem with usb driver
hi,
I have boot uclinux kernel successful,then i plug a usb disk on my board,that's ok.But it show errors when i run the follow code:
[/CODE]fdisk -l /dev/sda
fdisk:Bad command or file name
[CODE]mount -t vfat /dev/sda1 /mnt
FAT:Code page cp437 not found
mount failed:Invalid argument[/B]
please help me,thank you!
    --- Quote Start ---
    originally posted by hippo@Jun 5 2006, 08:41 PM
    add "make -c user/busybox clean" after step2.
    boot uclinux,
    run "busybox", to see what you have built in busybox.
    what is your rc now?
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15934)
    --- quote end ---
    --- Quote End ---
    Hi,hippo.
    It can mount usb disk automatic,but show another erro:
    <div class='quotetop'>QUOTE </div>
    --- Quote Start ---
    Command: mount -t vfat /dev/sda1 /mnt
    Kernel panic - not syncing: Attempted to kill init!
    Execution Finished,Exiting[/b]
    --- Quote End ---
    My rc:
    --- Quote Start ---
    hostname uClinux
    mount -t proc proc /proc
    mount -t sysfs sysfs /sys
    mount -t usbfs none /proc/bus/usb
    mkdir /var/tmp
    mkdir /var/log
    mkdir /var/run
    mkdir /var/lock
    mkdir /var/empty
    ifconfig lo 127.0.0.1
    route add -net 127.0.0.0 netmask 255.0.0.0 lo# dhcpcd -p -a eth0 &
    cat /etc/motd
    sleep 15
    mount -t vfat /dev/sda1 /mnt[/b]
    --- Quote End ---
    Now,i hope that it mount usb automatic when usb disk be detected,how can i do?
    I wrote a little shell script to mount the USB stick, but I dont know if this is the best solution. I wanted to port autofs first but it was to heavyweight.
    For the shell script I use /proc/partitions and /proc/mounts to automount.
    # !/bin/sh
    while true
    do
    grep sda /proc/partitions > /dev/zero
    if test $? -eq 0; then
    grep sda /proc/mounts > /dev/zero
    if test $? -eq 1; then
    echo "*** mount usbdisk ***"
    mount -n -t vfat /dev/sda /mnt/usb
    fi
    else
    echo "*** unmount usbdisk ***"
    umount -n /mnt/usb
    fi
    fi
    sleep 1
    done
    --- Quote Start ---
    originally posted by nacide@Jun 8 2006, 03:03 AM
    i wrote a little shell script to mount the usb stick, but i dont know if this is the best solution. i wanted to port autofs first but it was to heavyweight.
    for the shell script i use /proc/partitions and /proc/mounts to automount.
    # !/bin/sh
    while true
    do
    fi
    else
    umount -n /mnt/usb
    fi
    fi
    sleep 1
    done
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=16023)
    --- quote end ---
    --- Quote End ---
    hi,
    Thank your reply.
    I did follow your reply,but it can&#39;t work.
    It show "Bad command or file name" for every command which your reply.
    Can anyone tell me where i take a mistake?
    hi,
    Another question:
    How to run a shell script in my apps by execve() or other programmes?
    Thank you!
    zhengkaike,
    You need to have the commands that are called like mount, umount, grep, test, echo and sleep in your rootfs.
    Maybe it will also work with the busybox versions but I did not test this.
    I call the shellscript from the rc script in /etc
    for example
    automount.sh &
    --- Quote Start ---
    originally posted by nacide@Jun 13 2006, 04:05 AM
    zhengkaike,
    you need to have the commands that are called like mount, umount, grep, test, echo and sleep in your rootfs.
    maybe it will also work with the busybox versions but i did not test this.
    i call the shellscript from the rc script in /etc
    for example
    automount.sh &
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=16150)
    --- quote end ---
    --- Quote End ---
    Hi,nacide,
    Thank you!
    May be my busybox has some bugs,there are many errors when compiled.
    I have resolved the problem by using mount() and umount(), it can work successful although it&#39;s not a best method. The code:
    --- Quote Start ---
    char spe_file[20]="/dev/sda1";
    char cur_dir[]="/mnt/usb";
    char um_dir[]="/mnt";
    char subum_dir[]="usb/";
    int main(void)
    if(mkdir(cur_dir,O_RDWR)==-1)
    //"/mnt/usb"exsit
    if(umount(cur_dir)==-1)
    printf("erro : umount usb!\n");
    exit(1);
    chdir(um_dir);
    if(rmdir(subum_dir)==-1)
    printf("error rmdir %s \n",subum_dir);
    exit(1);
    printf("umount usb ok!\n");
    return 0;
    if(mount(spe_file,cur_dir,"vfat",2,(char *)NULL)==-1)
    printf("error :mount");
    exit(1);
    printf("mount usb ok!\n");
    return 0;
    }[/b]
    --- Quote End ---
    Thank you for your reply again.
