16 years agoProblem with SDRAM
Hello Folks, i really have a problem with my Nios running on external SDRAM... I try to get my own bord running and the code has to run from SDRAM. I know the problem with the phase s...
16 years agoHi
If you are not driving the SDRAM_CLK pin it gives wrong outputs you can use a PLL and generate a seperate clock and drive the sdram clock regards M Kalyansrinivas
