20 years agoproblem with sdram
hi
i built my own board with a EP1C20 and flash and the sdram (MT48LC4M32B2 -7). i use the nios I and i don't manage to work properly with the sdram. When i write at the adress 0 i read the value at the adress 0x0 and 0x2 and 0x100 0x102 0x800 0x802 0x900 0x902 and 0x2000 and so on. I verified many tilmes all my pin out. the sdram is not close from the the FPGA. there is no influence when i change the phase shift of the sram_clk(50MHz). Is there a knew problem with sdram controler and nios I? I need some help!!!! thanks benjamin1 Reply
--- Quote Start --- originally posted by benjamin@Sep 30 2005, 04:42 AM hii built my own board with a ep1c20 and flash and the sdram (mt48lc4m32b2 -7).
i use the nios i and i don't manage to work properly with the sdram.
when i write at the adress 0 i read the value at the adress 0x0 and 0x2 and 0x100 0x102 0x800 0x802 0x900 0x902 and 0x2000 and so on.
i verified many tilmes all my pin out.
the sdram is not close from the the fpga.
there is no influence when i change the phase shift of the sram_clk(50mhz).
is there a knew problem with sdram controler and nios i?
i need some help!!!!
thanks
benjamin
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10064)
--- quote end ---
--- Quote End --- hi sir.. i am working on EPIC6 board and want to access the sdram thru both s/w(c-prog) and h/w(custom instr).what should i do to access the sdram.. i have seen an eg. in which EXPORT ports from the CPU were used to access the LEDs so should i do the same to access the sdram...plz suggest the way u have accessed the sdram. byeeeee
