13 years agoproblem with mutex core
Dear all, I've created a qsys system composed of two NIOS, each one attached to its on-chip memory that contains its program. the two processors are connected to a shared RAM protected via a ...
13 years ago --- Quote Start --- Firstly make sure that the memory area you are using for SHM isn't also used by some other part of the system. I'd then use a sequence something like: 1) CPUB: write C0 to SHM(0) 2) CPUB: wait for SHM(1) to be C1 3) CPUA: wait for SHM(0) to be C0 4) CPUA: Acquire mutex 5) A: write SMH(1) C1 6) B: Acquire mutex (should spin) 7) A: Loop for a moderate fraction of a second 8) A: Write SMH(0) C2 9) A: Release mutex - B should run 10) B: Check SHM(1) is C1 and SMH(0) C2 11) B: release mutex I've not used the Altera mutex functions, and I wouldn't consider using and of the IOWR_32DIRECT() family of functions in any code I ever wrote - they are far, far, far, far too error prone. You really need to use C pointers and structures (but not bit fields of enums) to map hardware registers. You might need access functions (to do cache bypass, or because the 'pointer' actually references a different memory space), but you need the verificatiion that the offsets match the device pointer. --- Quote End --- Please could you tell me how to make CPUB waiting for SHM(1) to be C1?? isn't this guaranteed by the mutex?? if one processor acquires the mutex, it doesn't mean that the other can't acquire it?? if you can provide me an example of code, I'll be very thankful,
