13 years agoproblem with mutex core
Dear all, I've created a qsys system composed of two NIOS, each one attached to its on-chip memory that contains its program. the two processors are connected to a shared RAM protected via a ...
13 years agoFirstly make sure that the memory area you are using for SHM isn't also used by some other part of the system.
I'd then use a sequence something like: 1) CPUB: write C0 to SHM(0) 2) CPUB: wait for SHM(1) to be C1 3) CPUA: wait for SHM(0) to be C0 4) CPUA: Acquire mutex 5) A: write SMH(1) C1 6) B: Acquire mutex (should spin) 7) A: Loop for a moderate fraction of a second 8) A: Write SMH(0) C2 9) A: Release mutex - B should run 10) B: Check SHM(1) is C1 and SMH(0) C2 11) B: release mutex I've not used the Altera mutex functions, and I wouldn't consider using and of the IOWR_32DIRECT() family of functions in any code I ever wrote - they are far, far, far, far too error prone. You really need to use C pointers and structures (but not bit fields of enums) to map hardware registers. You might need access functions (to do cache bypass, or because the 'pointer' actually references a different memory space), but you need the verificatiion that the offsets match the device pointer.
