Problem with converting files
Hello RSher11,
I'm looking into your issue.
You can try these next steps and tell me what's happen?
1) add a new region called .video_buffer and assign it to the emif linker region / memory device name (they have already done this)
2) in the lower section of the window: Linker Memory Regions, click Add and give the name of the new region video_buffer with a memory device name set to emif
3) adjust the size of the original emif (I reduced it in half) and set the video buffer depth to half of what I had available
4) after building the bsp, and writing a simple hello_world program to intialize the video buffer and print it out, my elf size is approx 6KB
Best regards.
Hello, Isaac_V_Intel,
Sorry for the late response. I tried to create small test project on your recommendation. It worked. But when I tried to use your solution in my working project I got that issue again.
I attached some additional information about program size for my test and working project respectively.
Info: (my_project.elf) 3548 KBytes program size (code + initialized data). Info: 65436 KBytes free for stack + heap.
Info: (my_project.elf) 13386 KBytes program size (code + initialized data). Info: 63801 KBytes free for stack + heap.
