15 years agoProblem with accessing Avalon MM slave custom logic
I have my custom logic (simple ALU) verilog as below:
case(address) //2'b00: opcode <= writedata[1:0]; 2'b01: data1 <= writedata; //2'b10: data2 <= writedata; //default: readdata <= result; default: readdata <= 32'h87654320; endcase Here is the C code in Nios2: z = IORD(ALU_AVALON_0_BASE,result); //z = *result; printf("Result is:\t%08x\n\n", z); I got the correct result for above code. However if i change the 32'h87654320 to 32'h87654330 or 32'h87654340, the result become 00000000. This is strange as i have making sure i re-compile everything (both Quartus and Nios). Please advice whats is going wrong here...No RepliesBe the first to reply
