16 years agoproblem to use quartus from Nios II SDK bash shell
I have installed quartus 9.1 software suite in ubuntu. I have built the script for a Nios II SDK bash shell. In the shell when i use the command "quartus" i receive this errror: rpm: Command n...
16 years agoIf what I think you mean is correct and you are using "NIOS II shell" using the environment provided by altera, it seriously messes up your PATH. Do not use it, I think it is for windoze users (bash is a shell that comes default with linux). Just manually set you environment and then try it.
export QUARTUS_ROOTDIR=/opt/altera9.1/quartus export PATH=$PATH:$QUARTUS_ROOTDIR/bin export PATH=$PATH:$QUARTUS_ROOTDIR/../nios2eds/bin ...... ..... I would recommend learning about UNIX shells, and when it comes to linux, ease of use and installation would not get one anywhere, one needs to get his/her hands dirty.
