15 years agoProblem rebooting Nios II from uClinux
Dear all, I need to reset Nios II from uClinux. I tried to use "reboot" app from sash but it didn't work. The response is Restarting system and then system freezes. I'm working on...
15 years agoYes I agree. Putting a system in flash and having the CPU's reset vector to the flash should make it work after a reset.
Also note that even if the CPU's reset vector is on flash, you can still upload a software image through jtag and run it on the CPU. But if you reset it it will revert to the flash image.
