problem of large design with Qsys
Hi all,
I'm designing a network of processor (Nios II) with Qsys 11.1. There are 32 niosII in my design and I use the ip-generate command-line. The issue is Qsys can't generate the sopcinfo file: --- Quote Start --- Info: system: Done system" with 98 modules, 4296 files, 88115683 bytes Error: Error writing sopcinfo report java.lang.OutOfMemoryError: Java heap space Info: ip-generate succeeded. Info: Finished: Create HDL design files for synthesis --- Quote End --- Anyone has idea? Thanks! ps: I tried to close and reopen Qsys16 Replies
I pinged someone about this and they believe what is passed by ip-generate will overwrite the global setting. So if the global doesn't work I think hacking the .exe will be your only option (for now, it's being looked into)
Do you think modifing the ip-generate.exe could change NiosII rights of the license ?
I'm not really sure. I think the lawyers have better things to do than pursuing someone who hacks a fix into an .exe file though :)
Hello - has anyone come up with a better solution to this then hacking the executable?
I am running the Quarts 11.1sp2 tools under Linux and am getting the same JVM error as reported earlier: ( Error: Error writing sopcinfo report java.lang.OutOfMemoryError: Java heap space java.lang.OutOfMemoryError: Java heap space) Thanks Kevin. - Altera_Forum
As an update, this is listed as an SPR (spr362079). I have seen that a large QSYS system gets the OutOfMemory error from the JVM in using either ip-generate or the GUI. Paring the system back by some number of components resolves the error but not the problem.
I am hoping that Quartus 12 will solve the problem. Kevin. - Altera_Forum
FYI, ip-generate (I guess that it was changed in newer versions) in Quartus 13 has a --jvm-max-heap-size=<value> parameter
