15 years agoproblem of assign output pin
Hi, i create an IP, and i add with sopc builder to my nios system. It work perfectly with the nios. The only problem is, i don't know how to assign the input/output signal of my IP which ...
15 years agoI can't understand your question. :confused:
I thought you had already compiled the project. Maybe you mean you need this: File Menu -> Create/Update -> Create Verilog Instantiation Template for Current File
