20 years ago
Problem dloading vmlinux to 2C35
I was trying to download the vmlinux.flash image to the board and received this error
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Resetting and pausing target processor: FAILED
(I get this immediately so it's not the same problem as the one described as happening after 20 seconds for which Altera's put out a fix for)
I used the standard.sof and std_2C25.ptf but I'm not sure whether that is the correct design to use for linux or whether we need to create our own sof?
Also, I'm wondering why my vmlinux.flash size was so large at about 8.3 mb? Is it supposed to be that size since I saw this in the toolchain setup thread:
Memory available: 63744k/65536k RAM, 0k/0k ROM (694k kernel code, 417k data)
Lastly, since the flash memory size isn't too big, is it possible to use the RAM instead of the flash for the kernel? Would I need to compile the kernel with different options in that case?
Thanks a lot in advance!
    The 8 MB sdram of DEII is very tight for uclinux.
    remove unused applets in busybox, keep only init, msh, and some coreutils.
    remove unused files in ~/rootfs/etc, keep only inittab
    remove unused dev nodes in ~/download/rootfs_list, keep only console,zero,null.
    cd ~/buildroot/build_nios2/busybox
    make menuconfig
    make
    cd ~/buildroot
    make
    rm -rf ~/rootfs
    cp -a ~/buildroot/build_nios2/root ~/rootfs
    cd ~/rootfs#  remove include and lib to save space#  the dev nodes are generated via ~/download/rootfs_list
    rm -rf dev usr/include usr/lib etc/*#  you may use this instead of the one from buildroot
    cp ~/download/inittab etc#  clean headers for uClinux-dist
    cd ~/buildroot/build_nios2/staging_dir/include/linux
    rm config.h autoconf.h
    touch config.h autoconf.h
    cd ~/linux-2.6.x#  rebuild image for initramfs
    make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc-
    Thanks, hippo! Looks like its working now http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/laugh.gif
    uClinux/Nios II
    Altera Nios II support (C) 2004 Microtronix Datacom Ltd.
    Built 1 zonelists
    Kernel command line:
    PID hash table entries: 64 (order: 6, 1024 bytes)
    Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
    Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
    Memory available: 6984k/8192k RAM, 0k/0k ROM (704k kernel code, 385k data)
    Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
    Linux NoNET1.0 for Linux 2.6
    Serial: JTAG UART driver $Revision: 1.4 $
    ttyJ0 at MMIO 0x81004000 (irq = 1) is a jtag_uart
    io scheduler noop registered
    io scheduler deadline registered
    Freeing unused kernel memory: 304k freed (0xba000 - 0x105000)
    init started:  BusyBox v1.1.1-pre0 (2006.03.06-00:20+0000) multi-call binary
    BusyBox v1.1.1-pre0 (2006.03.06-00:20+0000) Built-in shell (msh)
    Enter &#39;help&#39; for a list of built-in commands.
    By the way, if I had to install the bluez module into the linux kernel as well as the driver for the IP core for USB, would that likely cause any problems with running out of RAM?
    Also, in the toolchain, the compiler used to compile was
    nios2-linux-uclibc-gcc hello.c -o hello -elf2flt
    If I already have a compiled object file (compiled with g++), is there any way of converting the object file with something like elf2flt?
    The kernel is working now.
    <div class='quotetop'>QUOTE </div>
    --- Quote Start ---
    By the way, if I had to install the bluez module into the linux kernel as well as the driver for the IP core for USB, would that likely cause any problems with running out of RAM?[/b]
    --- Quote End ---
    Add them one by one. It is still possible to run out of ram. Check in only what is required. Or if you could, change the sdram chip to a 16Mx16 device, check your PCB if extra MA lines are required.
    --- Quote Start ---
    If I already have a compiled object file (compiled with g++), is there any way of converting the object file with something like elf2flt?[/b]
    --- Quote End ---
    You can add the elf2flt flags. Note the libstdc++ might still have problems, it compiled and linked with elf2flt, but it crashed when running. I am not a c++ user, and I don&#39;t know how to resolve (and I am quite busy now).
    when i nios2-download -g vmlinux!
    it appears:
    SOPC Builder]$ nios2-download -g vmlinux
    ios2-elf-objcopy: &#39;./vmlinux&#39;: No such file
    /vmlinux.srec: Unable to open input file
    m: cannot remove `./vmlinux.srec&#39;: No such file or directory
    /altera/kits/nios2_51/examples
    why ?
    where my &#39;vmlinux.bin&#39; file shoulde lay?
    --- Quote Start ---
    it appears:
    sopc builder]$ nios2-download -g vmlinux
    ios2-elf-objcopy: &#39;./vmlinux&#39;: no such file
    /vmlinux.srec: unable to open input file
    m: cannot remove `./vmlinux.srec&#39;: no such file or directory
    why ?
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=14330)
    --- quote end ---
    --- Quote End ---
    the vmlinux is in your kernel build dir .
    and if you make zImage , arch/nios2nommu/boot/zImage .
    Note the drives mapping in nios2 sdk shell,
    drive c: is /cygdrive/c/
    drive d: is /cygdrive/d/
    if you map your linux home to h: on windows with samba server,
    then it is /cygdrive/h/linux-2.6.x/vmlinux
    or /cygdrive/h/linux-2.6.x/vmlinux/arch/nios2nommu/boot/zImage
