16 years agoProblem debugging after bootloader loades
I have an Arria II GX device with an EPCS device attached. On this EPCS device I'm storing both the configuration and the application for NIOS. I'm able to use the NIOS default bootloader in the EPCS...
15 years agoCan you elaborate on how you solved this problem (schematic,SOPC,pin planner,IDE settings,etc....)?
