16 years agoProblem about interval timer
Hi guys now i want to use the interval timer as interrupt to send a 40khz sine wave to i/o port.but when i set the interval timer as 1us which equals the sampling frequecy of ad5547(1mhz),it does'...
16 years agoThanks for you kindness!
I use the the fast nios cpu and the version of nios IDE is 8.0.Now I turn my way into designing the DA IP and add it into the SOPC systerm.As the same problem,I occur software problems,I couldn't get the correct result.Could you give some ideas about designing IP?
