16 years agoProblem about interval timer
Hi guys now i want to use the interval timer as interrupt to send a 40khz sine wave to i/o port.but when i set the interval timer as 1us which equals the sampling frequecy of ad5547(1mhz),it does'...
16 years agoIf it works with a lower frequency, it seems that the problem is rather in timing than in code.
Which version of the Nios II do you used (e/s/f) ? Because they have not the same performance, so if you don't use the fastest one, maybe try to use a faster version. Else I would say to check the behaviour in simulation, like that you can check if the Nios II can process the interrupt in the time allowed and if it is a problem of of timing or not.
