16 years agoProblem about interval timer
Hi guys now i want to use the interval timer as interrupt to send a 40khz sine wave to i/o port.but when i set the interval timer as 1us which equals the sampling frequecy of ad5547(1mhz),it does'...
16 years agoWith a clock of 20 MHz, that means only 20 cycles between the interrupt. I think this is not sufficient for the processor to make all the stuff it has to do (call of the interrupt service routine, make the job, and go back). You can verify this by simulation.
Can you use a higher frequency ? Jérôme
