20 years agoproblem about data transmission using DMA
Hi Every one:
I am writing a program that requires iterative access to image data which I placed on SD-ram (as on-chip memory is not big enough) I figured that the program can probably run somehow faster if I gets a DMA controller to read these image data from SDRAM to buffers that I placed on the on-chip memory and then process the data on on-chip memory instead of processing data on SDRAM. I wrote a function which opens up a DMA channel and carries out a DMA transaction and close the channel. I tested the function one DMA transaction one by one and verified the copied data to be exactly the same. But when I later integrated this function into my program which iteratively calls this DMA transmission function to transmit different section of an image from SD RAM to a fixed memory address on on-chip memory . I found out that the copied data are partially corrupted (some part of them are correctly copied but some data are corrupted in chunks) when I verified the copied data. I thought it was because i didn't close the channel properly, but this stil happens when i close both transmission and receiving channel at the end of the DMA function Anyone encountered similar problem? or have any idea how to solve it?? I attached the code of the DMA function below incase anyone is interested Thank you Tonyvoid DMATransfer(int x,int y)
alt_dma_txchan txchan;
alt_dma_rxchan rxchan;
int rc;
int offset;
int counta,countb;
int temp_x =0,temp_y =0;
void* data_written_1;
void* data_read_1;
void* data_written_2;
void* data_read_2;
data_written_2 = (void*)&data_frame_2;
data_read_2 = (void*)&temp_frame_2;
if (x == 0)
temp_x = 12;//adjusting pointer to the right position for writing
else
x -= 12;
if (y == 0 )
temp_y = 12;
else
y -= 12;
data_written_1 = (void*)&data_frame_1;
data_read_1 = (void*)&temp_frame_1;
counta = x+y*320;//data_written_1_count
countb = temp_x+temp_y*40;//data_read_1_count
// Create the transmit channel //
if ((txchan = alt_dma_txchan_open("/dev/dma")) == NULL)
printf ("Failed to open transmit channel\n");
exit (1);
// Create the receive channel
if ((rxchan = alt_dma_rxchan_open("/dev/dma")) == NULL)
printf ("Failed to open receive channel\n");
exit (1);
for (;counta< Y_SIZE*X_SIZE&&countb < 1600; data_written_1+=320, data_read_1+=40, counta+=320,countb+=40){
/// Use DMA to transfer from write buffer to memory under test /
// Post the transmit request /
if ((rc = alt_dma_txchan_send (txchan, data_written_1, 0x28, NULL, NULL)) < 0)
printf ("Failed to post transmit request, reason = %i\n", rc);
exit (1);
// Post the receive request /
if ((rc = alt_dma_rxchan_prepare (rxchan, data_read_1, 0x28, dma_done, NULL)) < 0)
printf ("Failed to post read request, reason = %i\n", rc);
exit (1);
/// Wait for transfer to complete //
while (!rx_done);
rx_done = 0;
for (offset = 0; offset< 16; offset++,data_read_2+=16,data_written_2+=320){
if ((rc = alt_dma_txchan_send (txchan, data_written_2, 0x10, NULL, NULL)) < 0)
exit (1);
// Post the receive request //
if ((rc = alt_dma_rxchan_prepare (rxchan, data_read_2, 0x10, dma_done, NULL)) < 0)
exit (1);
while (!rx_done);
rx_done = 0;
alt_dma_txchan_close (txchan);
alt_dma_rxchan_close (rxchan);
}No RepliesBe the first to reply
