15 years agoPrinting 32bit signed 2s complement data via JTAG UART
I'm trying to print out samples generated by the WM8731 audio codec on the DE2 board via the JTAG UART in a Nios II system. The samples are deserialized in Verilog HDL, squared (this is needed for a...
15 years agoYes, the audio codec returns a 16bit signed 2s complement sample which I am sending to the Nios system to be printed over JTAG UART (after squaring it).
Input signal: 2.4 Vpp, 500Hz, sine wave Using volatile char *:
audR: 1 audL: -126 audL2: 4
audR: 2 audL: 94 audL2: -124
audR: 1 audL: 110 audL2: 68
audR: 1 audL: 11 audL2: 121
audR: -3 audL: 8 audL2: 64
audR: 2 audL: 7 audL2: 49
audR: -1 audL: -3 audL2: 9
audR: 0 audL: 12 audL2: -112
Using volatile short * (obviously wrong results for audL2 since it is 32 bits but even audL is very different from char results):
audR: 0 audL: 12949 audL2: -30023
audR: 1 audL: 956 audL2: -3568
audR: 1 audL: -12180 audL2: -21104
audR: -3 audL: 5486 audL2: 15172
audR: 0 audL: 11626 audL2: 28644
audR: 2 audL: -6731 audL2: 20985
Using #define USB_Ctrl (volatile char *) 0x00005000
# define Data_in_1 (volatile alt_16 *) 0x00005010 // right channel samples
# define Data_in_2 (volatile alt_16 *) 0x00005020 // left channel samples
# define Data_in_3 (volatile alt_32 *) 0x00005030 // left channel samples squared
# define Data_in_4 (volatile alt_32 *) 0x00005040 // filter results
audR: -2 audL: 165 audL2: 27225 filt: 26076439
audR: -1 audL: 10419 audL2: 108555561 filt: 146741412
audR: -2 audL: -1139 audL2: 1297321 filt: 16184391
audR: -2 audL: 1243 audL2: 1545049 filt: 36079690
Removes the negative results problem, but I don't know how to make sense of this sample data now. how do i properly convert these sample values to a real voltage? Since I'm using 16bits, the ADC has a resolution of -32768 to +32767. The step size would be Q = (3.6 - 1.8 V)/2^16 = 0.0000275 V = 0.0275 mV (I'm a little unsure of the input voltage range for WM8731, the datasheet says the analog supply range is 1.8-3.6V). Is this correct?
