20 years agoposition independent code
Hi -
for my application I need the ability to load code from a filesystem. My problem is, that this works only with position independent code. And as far as I know the nios2-gnutools don't support the generation of pic code. To get around this, my approach so far is to 'patch' the elf-binary after linking. I straightened out my issues with data access but I can't think of a way to get around the 'call' opcode for function calls. In effect 'call' transfers execution to the constant address encoded in the opcode. But for position independent code I need something of a pc-relative jump. I know there is 'callr', but the compiler generated code doesn't provide the address in a register as needed by 'callr'. And I can't modify the opcode, because I only have 1 instruction 'slot' available. I can't insert new opcodes because this would break the (compiler calculated) intra-function branches. My question is, has anybody previously tried to load code to an (at link time) unknown address, and what are your experiences? Thanks, WolfgangNo RepliesBe the first to reply
