15 years agoPorting PIO C-code from ARM-7 to Nios II (SE1-board) + performance issue.
Hi all, I'm having a try at the moment to port my C-code from the arm-7 mcu, LPC-P2148 to Nios II, SE1-board , Cyclon-II, EP2C20F484C7. The arm-none-eabi-gcc compiler was used for the ARM-7 ...
15 years ago --- Quote Start --- I sure would like to understand how a single core can achieve 1.13 MIPS/MHZ. It must complete more than one instruction per cycle, i.e. 2 per cycle about 13% of the time? --- Quote End --- The 1.13 MIPS/MHz are DMIPS/MHz. DMIPS is a calculated value based on the benchmark test. A value >1 does not necessarily mean, that the cpu can perform more than one instruction per cycle. The MIPS/MHz value for the Nios /f core should be less than 1, otherwise NIOS II/f would be a superscalar architecture.
