15 years agoPorting PIO C-code from ARM-7 to Nios II (SE1-board) + performance issue.
Hi all, I'm having a try at the moment to port my C-code from the arm-7 mcu, LPC-P2148 to Nios II, SE1-board , Cyclon-II, EP2C20F484C7. The arm-none-eabi-gcc compiler was used for the ARM-7 ...
15 years agoIMHO a cache does not signicantly improve the NIOS II/e performance. I think the 0.15 MIPS/MHZ are the best case achievable. A slow memory/memory interface worsens this value. NIOS II/e does not have a pipeline so instructions are executed one after another. An instruction has several stages, so the execution of one instruction lasts several clock cycles even if the attached memory can be accessed in one clock cycle. A fast memory/cache can reduce the length of the code fetch stage or the write back stage to a minimum, but it will still last several clock cycles before the next instruction is fetched.
