19 years agoPolling & INTs with NIOS II
Hi, I have 2 cascaded processors with a shared memory. The first processor writes its data in the shared memory and when it finishes, the second processor must be notified that the data is availab...
19 years agoHey Banx,
Thanks for ur help, it worked but I am moved to a new problem http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif It's the shared memory + software program controlling PIO. Shared Memory ========== I am using Cyclone1 NIOS II dev. kit, I thought of making CPU1 work from the SDRAM (Inst.+Data) and make CPU2 have an onchipmemory by using the RAM bits (Inst.+Data) and I have also a shared memory in between them as an onchipmemory. The RAM bits aren't enough !!! (294,000 only while I need a lot). My program needs about 380KB. So, I started checking the other memories (SRAM & SDRAM) to be the (Inst.+Data memory for CPU2). * I thought of SRAM coz I need separate memories for both CPUs coz they will be working as pipelined processors i.e working in the same time with different codes. Thus, I connected the SRAM to the inst. & data master of CPU2 but I get a strange message in the board settings saying that "sram/s1/data/data[28] and sram/s1/data/data[12] are in the same bus and shouldn't have the same pin assignment" and so on for the rest of the SRAM pins. * Speaking about the SDRAM, is there a way to divide it between the 2 processors with each working in the same time & using different ranges for their inst. and data, or it can't be done due to sharing same control lines ? Software ===== I have read countbinary.c & I am a bit confused about the method of dealing with PIOs in software especially the part of definitions. Are there certain definitions that must be made for PIOs in the c-file like those in system.h & countbinary.c ?
