21 years agopointer out of range link error
I have some code running from SDRAM that references an on chip RAM. In porting from NIOS to NIOS II I'm getting the link error global pointer relative address out of range I saw a topic t...
10 years agoHello,
after almost 12 years I've got a similar problem!! I am using Quartus 14.1sp1 and a NIOS II gen2. I get the following error while trying to compile my application (working in Quartus 7.1, NIOS II classic): obj/default/lpc_lib.o: in function `lsp_to_freq':lpc_lib.c:649: warning: unable to reach (null) (at 0x800476b8) from the global pointer (at 0x8003f5d8) because the offset (32992) is out of the allowed range, -32678 to 32767.
collect2: error: ld returned 1 exit status
make: *** [rio_audio_codec.elf] error 1 I tried to define all the extern variables with the "[]" at the end (as suggested above), but the problem is still present. I tried also to use the -G0 flag in the application, but the problem was not solved. Should I also specify the same flag for the BSP ? If so, how? Anyway I'd like to solve the problem definetely (without using the -G0), also because I need to reach some performance. Any hint is more than appreciated, thanks on advance
