Please can we have some help on the WSL\NiosIi\Eclipse build problems following the windows update
Hi @DavidCambridge,
Sorry to hear that and apologies for the inconvenient, to double check the above workaround to use the NIOS2 command shell does not work for you to build the design?
Also the patched that you mention you have tried is it in the following KDB? And that is also not working?
Possible to share what are the quartus version that you have tried those step and the error message that you are seeing?
You are using WSL 1 yes?
Warm regards.
Thanks again for the response. Regarding your questions:
‘to double check the above workaround to use the NIOS2 command shell does not work for you to build the design?’ Yes, that is correct the workarounds do not work. After making the suggested changes, I now get the error message “nios2-elf-g++.exe: error: missing argument to '-msys-crt0='”
‘Also the patched that you mention you have tried is it in the following KDB? And that is also not working?’ Yes, that is correct. I find after applying the patch I can’t generate the BSP. It fails with an unable to execute wsl dos2unix error.
‘Possible to share what are the quartus version that you have tried those step and the error message that you are seeing?’ . Please refer to me post above. I have described the quartus version numbers, the installation error messages, and I refer you to the above comment where I note after installing the patch it breaks being able to generate the BSP.
‘You are using WSL 1 yes?’ - at the moment I’m on version 1, I’ve also tried 2, but that also failed.
I do appreciate the help I’m getting here, but I think it’s also fair to point out that it’s almost a month since I raised this post and longer since others pointed out the same problem - hence I’d really appreciate it if we can get this fixed.
Thanks in advance
David
