Please can we have some help on the WSL\NiosIi\Eclipse build problems following the windows update
Hi @DavidCambridge,
By any chances did you managed to look into the workaround mention?
Please do let us know if you have any issues completing those steps and we would be more than happy to look into it.
Warm regards
Hi @DavidCambridge,
Hope this message find you well and good day, as we do not receive any response from you to the previous clarification that we have provided. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
Warm Regards
- DavidCambridge5 years ago
Hi
I was not able to get the procedure you describe to work. I did however find the below post which gives a link to a patch.
Unfortunately, when I try and apply the patch I get an error messages to tell me that the patch is for version 20.1.0.177 but I have version 20.1.0.711. I then visited the quartus down load page to see if there was a later version, but I struggled to download using this account. When I tried I was locked in an endless loop between the download page and the account login page. To solve this I had to create a new account, but then I discovered the latest version us 20.1.0.711 ?
David
I should add to the above that if you apply the patch anyway, and regardless of the version mismatch, it doesn't work and the build problems still exist.
- BoonBengT_Altera5 years ago
Moderator
Hi @DavidCambridge,
Sorry to hear that and apologies for the inconvenient, to double check the above workaround to use the NIOS2 command shell does not work for you to build the design?
Also the patched that you mention you have tried is it in the following KDB? And that is also not working?
Possible to share what are the quartus version that you have tried those step and the error message that you are seeing?
You are using WSL 1 yes?
Warm regards.
