11 years agoPIO problem
hai, I am using nios ii .I generated the components using Qsys and works fine.But when i add a single PIO to the existing Qsys whole thing gets collapsed. What can be the reason for this? I am...
11 years agoDid you re-generate BSP? and re-compile software codes (elf)?
What does the PIO connected to? Did you enable interrupt for the PIO?
