10 years agoPIO Bitwise operation
Hallo, What is the best way to perform bit wise operation to clear or set specific bits on Nios II PIO port? An example CTRL_PORT = CTRL_PORT | (1 << CTRL_CS) | (1 << CTRL_RDE) | (1 <...
10 years agoWhen you instantiate a PIO in Qsys, you can optionally enable the single bit clear/set feature.
You can then use the IOWR_ALTERA_AVALON_PIO_SET_BITS / IOWR_ALTERA_AVALON_PIO_CLEAR_BITS macros. Enabling this option you spare the instructions required to read the actual pio status and masking the existing bits.
