10 years agoPIO base address constant, defined on design
Hi, I have made some experiments on NIOS2 core with the Avalon PIO and it’s working fine. However, differently from some examples found on the Web, e.g iord(pio_0_base,0) - I had to ma...
10 years agoYou should be able to look up your PIO_0_BASE in your system.h. I assume that you have generate/re-generate BSP based on the new sopcinfo file.
