PHY MDIO physical base address on Cyclone V SoC
Hi
I am working on interfacing a second PHY which is connected to one of the HPS EMAC using FPGA IOs, but I have some MDIO issues on my Cyclone V SoC board. The PHY responds correctly on the MDIO interface (checked with Signaltap) but the linux driver only reads zeros.
To do some simple debugging I want to use memtool to access the MDIO interface. According to https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd10052010_44.html
this should be straight forward:
“Read access from an external PHY can be done using the MDIO interface as follows:
- Perform an Avalon-MM master write to the MDIO core registers at address offset 0x21, specifying the external PHY device address (MDIO_DEVAD), port-address (MDIO_PRTAD) and register address (MDIO_REGAD).
- Issue an Avalon-MM master read of the 32-bit MDIO_ACCESS register at offset 0x20. "
However, I am missing a key parameter: What is the base address for MDIO access?
E.g. emac0 and emac1 are mapped to base address 0xFF700000 and 0xFF702000, but I can't find any information about MDIO.
Anyone who can help me out?
BR
AD
Hello sir,
The MDIO can be accessed via GMII_Data & GMII_Address.
Please refer to the TRM:
GMII_Address on page 18-151
The GMII Address register controls the management cycles to the external PHY through the management interface. The offset is 0x10.
GMII_Data on page 18-154
The GMII Data register stores Write data to be written to the PHY register located at the address specified in Register 4 (GMII Address Register). This register also stores the Read data from the PHY register located at the address specified by Register 4. The offset is 0x14.
Hope this might help
1 Reply
- FawazJ_Altera
Hello sir,
