21 years agoPerformance of NIOS II is 15.5 DMIPS...
Hi All, I just ran the Dhrystone program on a "standard" design of a 1S10ES eval. board running at 50Mhz. I get a performance of 15.5 DMIPS. This is without any changes to the default synth...
21 years ago --- Quote Start --- originally posted by soin@Apr 19 2005, 10:33 AM hi affluent007,
i've a stratix development board 1s10 and i've increased the processor clock till 100 mhz. i've set the "e" output to the sdram at 100 mhz too, mantaining the same phase shift in ns (for my board is 3.5 ns).
it works. --- Quote End --- Hi Soin, I tried it as you said but I'm getting timing violations. The best I can get is: 91.96 mhz ( period = 10.874 ns ) What setting are you using to get 100Mhz? I tried the settings suggested: - Perform physical synthesis for combinational logic - Perform register duplication - Perform register retiming I set the optimization to "Speed" with no help. Thanks.
