20 years agoPerformance Issues
I am in the process of debugging a custom Nios II system. I have implemented a NIOS II/f CPU with and EPCS controller. I have created a custom component to access a SRAM in which my firmware is runni...
20 years ago --- Quote Start --- originally posted by shmueld@Jul 11 2006, 10:53 AM thank you everyone for all your information.
mschmitt, when you stated :-
"nowadays the readdata is a wire with a set of combinatorical logic and now each access is only 1 clock cycle long, regardless of read or write."
what did you mean ?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16796)
--- quote end ---
--- Quote End --- With this statement i mean that the oldway i did a avalon slave was : internal_signal -> DFF -> ReadDatabit where the internal_signal was combinatorical with the internal signal selected by the address. Now i have changed that in a way that i have removed the DFF. ReadData is now a wire instead of a reg (in verilog language) wire [31:0] avs_MyModul_readdata; assign avs_MyModul_readdata = ( avs_MyModul_address === 6'H00 ) ? { 32'd12345678} : ( avs_MyModul_address === 6'H01 ) ? { 32'd87654321} : { 32'd87654321}; Reading from slave address 0 will be 1234567, address 1 will be 87654321 and all others will be 0 this read is only 1 clock cycle long (or short :-) ) no need to assert avs_MyModul_waitrequest is it now clear to you ? Michael Schmitt
