20 years agoperformance degradation
We are running heterogeneous multiprocessor NIOS2 cores on out Stratix2 fpga. We have made a benchmark that contends for a shared memory locked by a hardware mutex, performs a multiply-accumulate, an...
20 years agoFirst, I want to explain that this is for research, so we are trying to model contention and that is why our code might seem simple and trivial.
The CPUs are using the sdram for instruction and data memory. They have small 4kb caches, but our code is extremely small. We are basically using an architecture like the one in the 3 processor tutorial by Altera. The strange thing is, we don't see a considerable degradation in performance from the fast processors (performance data below code). For the code, CPU1 reads macarray index 1-3, CPU2 reads from 4-7, and CPU3 reads from 8-10. We run the code on all processors at the same time so they will fight for the lock. We expect the lock contention to increase, as it does, however everything else (execution/loop iter) seems like it shouldn't vary too much in execution time. our code is:# define FAST 2666667# define STAN 1000000# define ECON 200000 # define LOOP FAST int main(void) { int i,j; int id = 1; int temp; macarray = (int*)MESSAGE_BUFFER_RAM_BASE; for(i=1;i<4;i++) IOWR(&macarray,0,1);
mutex = altera_avalon_mutex_open("/dev/message_buffer_mutex");
perf_reset(performance_cpu1_base);
perf_start_measuring(performance_cpu1_base);
perf_begin(performance_cpu1_base, 1);
for(j=0; j< loop; j++) {
for(i=1; i<4; i++) {
perf_begin(performance_cpu1_base, 2);
perf_begin(performance_cpu1_base, 3);
altera_avalon_mutex_lock(mutex, 1);
perf_end(performance_cpu1_base, 3);
temp = iord(&macarray,0); IOWR(&macarray[i],0, temp*i + temp); altera_avalon_mutex_unlock(mutex); PERF_END(PERFORMANCE_CPU1_BASE, 2); } } PERF_END(PERFORMANCE_CPU1_BASE, 1); PERF_STOP_MEASURING(PERFORMANCE_CPU1_BASE); in terms of performance: for 2 CPU fast total 3707864005 lock contention 2727460037 loop iteration 122.5504807 for 3 CPU fast total 5219197128 lock contention 4230256283 loop iteration 123.6175902 for 2 CPU standard total 4004902599 lock contention 2745356939 loop iteration 419.8485533 for 3 CPU standard total 8519047729 lock contention 6664269607 loop iteration 618.259374
