10 years agoPerformance counter report
Hey
I am running performance counter on my C code My problem is that the report only show the result for section 1 !! (even if I change sections order it only show the first) It should show 4 sections ! What could be the problem ?! thnx %%%%%%%%%%%%%%%% perf_print_formatted_report((void *)PERFORMANCE_COUNTER_BASE, ALT_CPU_FREQ,4, "section_1", "section_2", "section_3", "section_4"); %%%%%%%%%%%%%%%%%%%%%%%%%%%%%% --Performance Counter Report-- Total Time: 3.35524 seconds (335524437 clock-cycles) +---------------+-----+-----------+---------------+-----------+ | Section | % | Time (sec)| Time (clocks)|Occurrences| +---------------+-----+-----------+---------------+-----------+ |section_1 | 0.27| 0.00905| 905319| 1| +---------------+-----+-----------+---------------+-----------+ |section_2 | 0| 0.00000| 0| 0| +---------------+-----+-----------+---------------+-----------+ |section_3 | 0| 0.00000| 0| 0| +---------------+-----+-----------+---------------+-----------+ |section_4 | 0| 0.00000| 0| 10175| +---------------+-----+-----------+---------------+-----------+2 Replies
It's hard to know without seeing more code, but perhaps you are forgetting to change the second parameter of the PERF_BEGIN/PERF_END calls for the different sections?
... // Section 1 PERF_BEGIN(PERFORMANCE_COUNTER_BASE, 1); foo(); PERF_END(PERFORMANCE_COUNTER_BASE, 1); // Section 2 PERF_BEGIN(PERFORMANCE_COUNTER_BASE, 2); bar(); PERF_END(PERFORMANCE_COUNTER_BASE, 2); ... - Altera_Forum
--- Quote Start --- It's hard to know without seeing more code, but perhaps you are forgetting to change the second parameter of the PERF_BEGIN/PERF_END calls for the different sections?
--- Quote End --- thnx I solved it... // Section 1 PERF_BEGIN(PERFORMANCE_COUNTER_BASE, 1); foo(); PERF_END(PERFORMANCE_COUNTER_BASE, 1); // Section 2 PERF_BEGIN(PERFORMANCE_COUNTER_BASE, 2); bar(); PERF_END(PERFORMANCE_COUNTER_BASE, 2); ...
