19 years agoPerformance Counter offset
Hi, i have a question about the PERFORMANCE COUNTER component. I have the following code to measure the overhead from starting/stoping the counter: PERF_BEGIN (PERFORMANCE_COUNTER_BASE, 1);...
16 years agoI'm disable the Instruction cache in SOPC CPU and it give me errors. It is set to 2Kbyte of cache. So I enable back in SPOC and tried to add in alt_icache_flush_all() before the performance counter and it still give the different clk count. In my SPOC there is a shared memory between CPU and FPGA. I created a Dual memory port RAM using custom instruction and link to CPU. It has a fix latency. Could this create the different in clk count?
